First, these may appear to be a relatively "inexpensive" swaps, but remember it requires X-over steering and a decent amount of fabrication. Brake lines, custom shackles, driveline changes, U-bolts, it all adds up.
On the front - 44044s. On the early trucks, if you choose to keep the front spring mounts (which you can use) - you'll be going to a longer shackle in back. This is good for lift, BAD for pinion angle. So to adjust the pinion angle, you cut and rotate the axle itelf (complete removal, strip, and tear down). Based on other posts on this board, I rotated 1.5 degrees for every inch of lift. I figured that I was lifting about 6 inches - so I needed to rotate 9 degrees. If you choose not to rotate the axle you will have a very poor pinion angle.. Probably unusable. If you rotate with shims, you'll have castor and driveabability issues.
If I could do it over again, I'd probably rotate 14 degrees or so when using the extended shackles in back. The rear shackles contribute to poor pinion angle just as much as the lift.
If you do cut and rotate your axles, you now need to pay attention to your castor. You'll need to remove the spring perches and reweld. You should do this on an absolutely flat surface and make sure that you get 3-5 degrees of castor. This is what keeps your truck from wandering all over the road.. avoid the death wobble... There is a special tool for this that's cheap. I measured my castor angle as a difference between the straight part of the frame and then angle of my spring perch. <3 degrees of castor, you may have stability issues.
Rear:
Rear isn't that bad... I didn't have to extend my driveline, the 1/2 chevy springs are very available and easy to install. I used my existing spring perches and extended shackles.
Only negative, I don't have enough lift to match the front of my truck a fter installing these
I went to an add-a-leaf (rancho, I believe) which claimed to add 1-1.5 inches. Still, not enough lift.
Solution - For me, the solution will be the add-a-leaf, and changing the rear spring perch so that it forces my shackle to a more vert angle.. I recognize that I shouldn't exceed 45 degrees or so, but there is some lift to be had here.
If I had to do it again, I'd probably look for 3in 1/2 chevy leaf springs - IE springs that have been rearched.. Block blow!!
Overall, I'm sure I've spent around $1k to do this - majority of that on the cross over steering (use the Marlin, it's stronger). That doesn't include the gear change, lockers, or wheels and tires... Remember, if you ain't gonna keep it, you're going to loose all kinds of cash on a deal like this if you go to sell it!
Rear:
