1 - 12 of 12 Posts
is one side of the spring supposed to be on a certian side of the truck? my truck is leaning about 1.5-2 inches to the drivers side... any ideas?
Originally posted by DSI:
<STRONG>what front axle? toyota axle?? if it's a toy axle did you add the 3/8in plate to teh left perch??</STRONG>
dana 44 from a wagoneer. i don't believe that it's the perches, when i look at the shackles one is deffinatly angled farther than the other...
<font color="yellow">If it's a D44, it won't be the perches. DSI asked because a Toy front axle has the spring perches at different heights (one is partially onto the diff) so unless you added a spacer it would sit crooked.
With the D44, it's not an issue. If you bought them new, return them and get a new set, I guess.</font>
how old are they? let em settle.
Originally posted by dangerber:
<STRONG>Do you have a full tank of gas?? <IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
doesn't matter full or empty
i will check the shackle bolts tonight, this in on level ground. I have had them on for about a month, how long does it take to settle?
I bet they are still settling, springs take a while to settle, and a lot of times they settle at differnt rates, i would think that they will settle, level, before too long...
If they do not end up settling evenly then i guess you have a bad spring and i would send em back for a new set.
good luck bud, later, <IMG SRC="smilies/wink.gif" border="0">
<font color="yellow"> I would return them now, while they're clean and pretty much new. Unless someone else has this problem, I'd be worried about them not taking the springs back because they were too used by the time you drive it around for a month.
As far as I know, this is a unique problem, and no one is sure if wainting will make it better or worse... So why not go the safe route and get new ones right away.
Oh, and if your gas tank isn't in the center of the truck (not sure what you have) full or empty will make a difference by weighting down one side of the truck. 20 gallons of fluid is heavy.</font>
1 - 12 of 12 Posts
