1 - 16 of 16 Posts
Rockwell 2 1/2 ton axles, U joint style shafts, welded rear/Detroit front diffs, shaved pans, DIY4x4 pinion brake kits, set up for GM square body leaf springs. Driveshaft ends, leaf spring plates and U bolts included. Asking (sale pending) for the pair.
New 47/17r16.5 Super Swamper LTB tires on Rockwell center 8 bolt Humvee double beadlock wheels. Always stored inside. Asking $2000 for the set of 4.
Used set of 14.5R20 Michelin XL military tires. 44" tall and 14.5" wide. Good tread but some sidewall cracking. Asking $700 for a set of 7.
These were intended for a project that was never completed.
Open to offers.
Location is Freeport ME 04222
Pics can be seen in the link below.
https://maine.craigslist.org/pts/d/2-1-2-ton-rockwell-axles-and/6428642882.html
could you get any farther away lol just what i'm looking for but way to far of a drive :(
47" Super Swamper LTB tires and Rockwell axles.
The tires have new tread and are on 16.5" double beadlock wheels.
The Rockwell's are U joint type. The rear is welded and the front has a Detroit locker. The bottoms has been shaved and they have DIY 4X4 pinion brakes.
These were all for a project that was never completed.
I will separate the axles and tires.
https://maine.craigslist.org/pts/6089981380.html
Discussion Starter #6
Rockwells
I do have the set of inner beadlocks for the original 37" tires but I'm not sure if they would work with the 47's. They are not currently installed.
I'm asking $2,000 for just the axles but I'm open to offers.
JQ
Discussion Starter #12
Shipping would be very high for over 700 pounds of tires. Unless you have some low cost shipping alternatives?
1 - 16 of 16 Posts
