1 - 2 of 2 Posts
Hi folks. Found a deal on a 92 Trooper. Will an MUA5 from a 92 Trooper match up to the engine in my 2002 Trooper with the 4L30? Considering doing a manual trans conversion from the diner rigs. Bell housing match up?
Thanks!
You would be better off finding an AR 5 trans to swap in.
Do you have emissions testing where you are? If not you are good, everything should bolt up, but you are gonna have a few check engine lights from the trans swap. If you do, then you will also need to swap ECUs, and I think your life will be much easier if you use an AR 5 from a 98+ trooper.
1 - 2 of 2 Posts
