1 - 6 of 6 Posts
there is a ton of info on this forum about building 4links, on truggies, buggies, jeeps, ect. but all these seem to be geared towards rockcrawling, a few for street use.
my buddy and i are thinking about linking up the rear of his full size blazer. this truck it pretty much built for pismo and mud, he has a yota for trails and rocks.
i was thinking the best option would be a double triangulated 4 link, i was also thinking of a wishbone 3 link. but just because that works for rockcrawling, doesnt mean it will work for hittin dunes.
so really, the question is what would you do differently when designing a rear suspention for sand dunes than for rockcrawling.
Jeff
Sounds like overkill for just sand and mud. Why not leaf springs? Just the challenge of building it? (which I totally understand)
You can have a boatlod of adjustment if you get some adjustable shocks and play around with adding and removing leafs. For an hours' work it would be a completely different rig every weekend.
-tom
-tom
Not at all my jeep takes more of a beating during duneing than all other time put together. (especialy the motor!)
I would look at the rear suspetion on some desert or stadium racing trucks. For the dunes you need it to soak up some big bumps.
beerman
Jeff
Design it with less anti-squat (compared to the crawler nembers you typically read), and minimize anti-squat gain throughout the wheel travel as a preference over a flat roll axis. Traction is much less in sand and mud, promoting more wheel hop if the AS% is high, and with the lower traction the roll steer effect is not as much of a consideration as stable traction (favoring a predictable AS% throughout the travel range).
FWIW, save money on the suspension and spend it on good adjustable dampening shocks and springs that resist fade. Make it lightweight.
Happy Trails!
1 - 6 of 6 Posts
