1 - 20 of 29 Posts
hows the geometry look? tips, pointers and remarks welcome:D
gimme the geometry comments....its tacked in place, things can change by an inch or two...hows roll axis, does anti squat look in check...
the axle will actually compress a little when it sits on my truck, the straps strech...
lowers are poly at the axle, 7/8" heims at the frame crossmember, uppers will be poly at the frame and heims at the axle......
its 1.75" .250wall dom.....lowers are 47" long, uppers are about 36". vert sep at the axle is ~10" and the lowers mount at axle centerline. vert sep at the frame mounts will be ~8" although the mounts are about a foot away from eachother...
wow, I never knew that Oakdale and Campbell used the same
brown recylcing containers! neat.
--Sherpa
pictures look nice. I have no idea on how it will work.
nice tube bends though. I'm using 1.75 x .375 DOM for
my links. that stuff is heavy..................
--Sherpa
soopatoy,
it was a joke. based on his info of him drawing pics on the
net while others are wheeling. I happen to be at "work"...
pretty much doing nothing, getting paid to do nothing is
nice.
--Sherpa
Discussion Starter · #11 ·
--Sherpa
jackass:flipoff2: :D
nozuk, im keepin the leave$, ever $ince the baby was born it$ gotta come from the junkyard or i gotta make it :p
sos, i was measuring eye2eye...
wheres all the suspension gurus and engineering types to gimme a thrashing???
when measuring the verticle seperration at the frame(or refering to it)on disimilarr length control arms where do you measure?
Hey booger, I like the whole 1/4 elliptical thing and how you mounted it. I have a question, as I'm not fully certain of how you actually mount a 1/4 elliptical. On the axle, I see a shackle that the spring mounts too. Are both ends of the shackle free, or is the bottom mount solid? Thanks. I really want to go 1/4 elliptical, it seems like to me, from my research, a better way to go than coils/coilovers/airbags, etc.
Rough guess at the roll axis in the pic below in red.
Looks pretty good to me, but as Pig said, getting the upp link about 5-10 degrees closer to level would move the instant center closer to the CG - mkae the suspension more neutral when it comes to squat/antisquat, unless my thinking cap is on backwards again.
You do realize that if the upper links are shorter than the lowers, the pinion will rotate DOWN as the suspension droops, right? That's definitely something to take into consideration, because the rear u-joint may bind if the whole axle droops a whole lot.
Running a center limit strap to stop the axle just before the joint binds may be nessecary with that design, and it may not. If you can make the upper closer in length to the lower link, the effect will be lessened considerably... but before you go to the trouble of making one like the green line below, put your current link in and see how much the pinion moves as the axle drops straight down. :)
Discussion Starter · #17 ·
RightPedal said:
Rough guess at the roll axis in the pic below.
Looks pretty good to me... you do realize that if the upper links are shorter than the lowers, the pinion will rotate DOWN as the suspension droops, right?
ive got a strap to limit complete axle droop(thus pinion angles)....i think the roll axis will sit a little taller up front as the lowers would converge farther forward(they are 11" apart at that mmount...
Booger Weldz said:
I've got a strap to limit complete axle droop(thus pinion angles)....i think the roll axis will sit a little taller up front as the lowers would converge farther forward(they are 11" apart at that mmount...
Just making sure on the limit strap. Binding u-joints = bad. :flipoff2:
You're right about the roll axis, then. Didn't think the lowers were that far apart under the t-case. But that nice, practically flat roll axis is the neat thing about the XX link design. Flat roll axis = practically nonexistent rear steer. :)
YES, booger............... That is good. Just try and keep that rll center as high as possible.
1 - 20 of 29 Posts
