1 - 4 of 4 Posts
i was out playing in the mud today in 2wd and i got stuck so i went to pop it in 4wd high and nothing at all happened. I know the t-case lever is fine. however on the front axle there are vacuum lines that go to a solenoid i believe. One of them is broken off and is just flapping there. Is that my problem? I thought that it was just for the locker? 1990 yj with a 2.5 5 speed
The vacuum lines engage a sliding collar on the axle-no vacuum-no front-wheel drive.
look into a posi lock (cable actuator). No more vacuum B.S.
Then weld the front spiders and you have a poor mans ox locker.
k
1 - 4 of 4 Posts
