1 - 15 of 15 Posts
4WU 3Link Bracket Kit:
LASER CUT, 1/4" plate, none binding design, 2 position link adjustment, zero bump steer, Relocates axle 1.5"- 4.5" forward. Includes 2.0" air bump cans, axle side shock tabs, bump can gussets, anti sway bar tabs, steering stop reinforcement. Plus frame reinforcement kit will come with this kit.
Check the link for more info:
Toyota 3 Link Kit
4WU 4Link Bracket Kit:
LASER CUT 1/4" plate steel, none binding design, 4 position link adjustment, variable mounting width for upper links, lower link mounting width 2.625" x 5/8", upper link mounting width varies for the user. Use up to a 2.625" at the frame and axle, depending on axle., built in bump pads, frame side brackets includes a MASSIVE 25" backing plate.
Toyota 4 Link Kit
Both kits are brackets only and located in Livermore, California. Spent nearly $1900 for them and changed priorities due to health. SOLD!
It looks like the front 3 link;
is based off the IFS toy frame or solid axle (re-inforce plates)?
is for stock toyota front axle?
is for stock pass drop upper link to pumpkin?
thanks
Duane
Check the link below for further info:
4WU/3Link
stock Toyota FJ80 front axle
yes
thanks
Duane
1 - 15 of 15 Posts
