1 - 6 of 6 Posts
Okay so All Pro is advertising this now on their website.
Anyone forsee problems with this low of a gear in the t-Case. I know some say that anything smaller than 5.29 in the dif is too weak but the t-case is a whole 'nother thing. Shouldn't be an issue right?
I was considering running it in my dual case with the 2.28s in the front case and this 5.0 or the 4.7 in the rear....
*EDIT* I guess they are for 21 spline applications. Chris says they are doing a 23 spline in a few months. Not a big deal I guess but I already planned on going with 23
but I want to crawl *now*!
Ramcock said:
its only a couple of teeth larger maybe you should wait for the 5.7 gear to come out.
Heh, nah. I'll be fine with 4.7s and I want to have mine together by the end of May for the dry weather up here.
The reason that 5.71s are considered weak is because the pinion head is small. I just ordered the 5.0 gears from inchworm got a good deal. give inchwormgear or rockbuggy supply a call They will both give you a pretty good deal on them. You will end up paying much less than what allpro has them advertised for.
www.inchwormgear.com
www.rockbuggysupply.com
1 - 6 of 6 Posts
