1 - 11 of 11 Posts
In my trusty 'Haynes' manual it says that there was a 4 speed available with the 1F, and the ratio of 1st gear was 5.299:1. My guess is that Toyota updated the transmission to 4 speed before they updated the engine to 135hp.
Now, my first gear is damn low, so I guess I have the H41 (4.925:1) or possibly this mystical F four-speed (Haynes does not give a model number for it). My FJ was already chev'ed when I bought it, but I think that it had an F in it originally.
Does anyone know anything about the 'F' four speed, and how can I tell what I have hanging off my bell housing? Also, Which engine would my rig have come out of the factory with, and is there any way to tell? It is a 9/1974.
Cheers
2car
The 5.3:1 first gear tranny was seen only on FJ55 models that I am aware of (early too, I think 1971-up 4 speed). If the top plate is pulled off the tranny, the 5.3 gear stands taller that the top of the cast iron body of the tranny. Very rare bird.
FYI, the "4 speed case" (with only 3 forward speeds) was introduced in mid 1967 as an option for the FJ55 (as well as power brakes!).
I should have the correct info on the 5.3 tranny in a week and can give a complete run down on models.....
H41 5.299 1st
Only in FJ55 1969-1970
H41 4.9 1st
all models with 4 speed outside US till 1980
The early H41 all same the same gears and innard but the Input and Counter shaft had a different teeth couth.
H41 4.8 1st
from 1981 to ... all the same gears as H55F
Discussion Starter · #9 ·
Yep it's a great reference. It must be the fj55 f and fourspeed combination Haynes is talking about.
Thanks everyone.
1 - 11 of 11 Posts
