Easier to find.why did you guys decide on 5.3 instead of a 6.0? Just considering options for myself.
i'm also wonering about this combo. i've read the 3550 is rated to handle 300 ft/lbs and some say that is underated. I enjoy driving the manual and would like to stick with it.my Bad Todd,, left out stock TJ 5speed to 5.3
Availability and money are the 2 biggest reasons. I originally got a high mileage 5.3 for dirt cheap from a buddy and was gonna build it into a high compression 5.7, but by the time I did all the machine work and got all the accessories and sh1t taken care of it made more sense to just go with a 6.0.....so that's what I did. Stock 5.3s complete with harness, computer, and all accessories can easily be had for under $1k depending on location. I paid $1400 for my 6.0.why did you guys decide on 5.3 instead of a 6.0? Just considering options for myself.
Common problem. Even with a small OD driveshaft it's very tight but doable. I switched to drivers drop partly for that reason since the trans pan is offset way to the passenger side. You could do a 2 piece driveshaft with a pillow block to offset it to clear the trans, or just go small OD 1 piece like lots of people do.I am having clearance issues with the front driveshaft with the engine swap that i am doing in my 82 cj8. the front driveshaft hits the trans pan. any help, pics or anything would be agreat help.any good shops in the Boulder, co area would be helpful, also.
I am currently in the middle of the swap into a TJ.do you have pics of this??? I had a 4x4 shop swap a 5.3, 700r4 and dana 300 in my 83 cj...they said the front drive shaft will be a 2 piece with carrier bearing. No big deal i guess, i just wanted to see how other were building these shafts.
Also does anyone have pics of there oil pans for the 5.3's I feel like the truck pan hangs down really low, and i dont like it at all. I dont know if its because of the way this shop mounted the motor or what, but its to low for my comfort. I was thinking of swapping out oil pans, but i dont know if anyone has done that before or not.
For better clearance I changed to a LS1 oil pan and pickup tube off a 98-02 Camaro. I got mine off CL, but think their are aftermarket companies that offer them.
What headers does everyone run between the TJ frame rails? I was thinking about using Edelbrock Shorty Headers with Ti-Tech Coating. They are $291 from Summit Racing. Deal or No Deal?
Craig's Listwhat is CL???
Block huggers from AA coated and fabbed my own crossover to run in front of the truck pan and down the passenger side.I...What headers does everyone run between the TJ frame rails? I
Thanks...I will check them out.i used advanced adapter headers with cermaic coating...they were only 225 bucks
I am running the Edelbrock Shorty Headers (rear dump) with ceramic coating. They fit great. I also ordered them from Summit. Part # EDL-65002I am currently in the middle of the swap into a TJ.
I spoke with Steve at AA and he claims they don't make a header for the 5.3 swap into a TJ. The headers they make will get into the upper control arm mount and motor mounts.I am running the Edelbrock Shorty Headers (rear dump) with ceramic coating. They fit great. I also ordered them from Summit.
I spoke with Steve at AA and he claims they don't make a header for the 5.3 swap into a TJ...
any center outlet blockhugger should work. Speedway sells some nice ones that aren't too expensive.
