Currently installed in my 72 commando, frame rails have the same spread as a CJ so the engine mount kit (nicely made bolt in crossmember and motor mounts) should work well on either. Runs great, 23psi oil pressure at hot idle in drive. Brand new not even dusty Edlebrock 1406 electric choke carb and air clearner. Serious torque set up. Th400 shifts real well, both could use pan gaskets as they drip just a bit.
$475 for the combo. I'll toss in the dana 20 if you want it. Offers welcome. I'm making way for a 5.3 install.
This is still installed, you can come hear it run, even drive it if your here before I sell the axles.
I can email pics.
I can email pics.
