Ok here's the question for you more experienced guys...
I have a 1959 Willys Wagon that I am attempting to mount to a Wagoneer Chassis. I figured the D44's front and rear, heavier frame, and 401 V8 were better than the '59's equipment. I have a wheelbase difference of about 6", that is to say the Willys is shorter. To take out the 6" and make the body fit which of the following is the best and safest thing to do???
a. Take 6" out of the center section of the frame?
b. Move the engine back 6" in the frame and make the driveshaft modifications it'll need?
c. Move the rear axle forward 6" by remounting the perches?
The only issue I see with option c. is that the hump in the frame will be in the wrong place if I simply move the axle forward.
Flame if you must, but I really do appreciate any help you can suggest. AJ
