1 - 12 of 12 Posts
Chubby Chaser
Does anyone make a bolt on skidplate to cover the cast oil pan on a 6.0? I noticed there's a few good size threaded holes at the bottom of the block I figured could be used for mounting.
engine skid needs to be attached to the chassis not the motor IMO otherwise all you will be doing in the future is changing broken auto trans cases when you hit the motor and the trans doesn't move.
Chubby Chaser
Discussion Starter #4
Good call Tom.
New engine for this car and the pan sits a bit lower than the subframe making it a little tricky to add one.
The picture of the whole in his pan looks like a truck pan which are about 8" deep. So a 5" kevko pan would be a good option but you could also go with an ls2 pan or f-body pan if you don't want to go to an external oil filter.
search around on here before making a switch though. the car oil pans have the pickup much farther forward and you really need to use an accumulator with them and if you have the f-body pan an Improved Racing baffle potentially as well. Quite a few people have kevko pans and they work as advertised but the fit and finish is pretty bad and you may have problems getting it to seal along the back edge. Dave Cole says he had a similar problem with his Kevko pan.
My Kevko pan dented even with a skid underneath it so there's no way an engine mounted skid will hold up to how we race.
LOL... I would break that thing in my driveway. Kevko will make building a chassis mounted skid a bunch easier. Fit and finish is .......ok? Wish somebody would make a good quality unit.
x3 on changing to to an f-body car pan. You'll need to modify the pickup a little bit, and cut some "slots" to allow the oil to move to the rear of the pan easier for climbs (which adversely effects going down steep things as well, but where would you want the oil pressure?) Or you could buy a Kevko.
1 - 12 of 12 Posts
