1 - 4 of 4 Posts
I know this may have been talked about somewhere, but search left me with nothing. I hear people talking about putting the 5on5.5 outers on the Waggy D44, but can it done the other way around?
Can I put the 6 lug outers from a Waggy D44 on an EB D44?
I dont see why I couldnt, I just wanted to make sure...
yea, use the gm or waggy knuckles... im using a eb axle with chevy flat tops, chevy outers, and eb inners.
if it has the 6bolt spindle you can use the stock eb knuckle. and a large bearing gm spindle/hub rotor
if it has 297 joints use the gm outer shaft if it has a 260 shaft remove .070 from the inner hub gear and use the stock eb outer shaft.
i have done the latter on a friends eb but used 8 lug hub/rotors to match the 60 he put in the rear until he could find a front 60.
1 - 4 of 4 Posts
