1 - 20 of 21 Posts
Hey y'all, I've heard the 05 unlimited rubi is getting the 6 speed, well the reg rubi has it too. Anybody know what type of trans it is? Is it a new guy? 3500 w/ another gear? Whats the deal?
http://popularmechanics.com/automotive/auto_technology/2004/8/chrysler_6speeds/
Jeep Liberty and Wrangler will feature the NSG 370 6-speed, replacing the two 5-speed manuals previously used--NV1500 and NV3550--reducing cost and complexity. The Jeep 370 is similar to the one used in the Chrysler Crossfire, the first 6-speed for the Chrysler brand. The NSG 370 has a 4.46:1 First gear, versus the 3.85:1 and 4.04:1 ratios of the previous 5-speeds, for improved launch and traction. For smooth operation, First and Second gears have triple-cone synchronization, Third and Fourth double-cone and Fifth and Sixth single-cone. The hard-finish gears run quiet says Chrysler, and the multirail steel shift system is strong and precise. The 2-piece aluminum case with integrated clutch housing assures powertrain stiffness and light weight. The overall 6-speed gear-ratio spread is intended to bring better fuel economy as well.
Quality has little to do with it. Basically they stuck an extra gear into a case that is roughly the same size. I'd be suprised if it's very durable. I can appreciate a lower first gear, but why would you want a 6 speed in a trail vehicle?
My guess would be its an EPA fuel mileage thing? I wouldnt want any more than 5 gears either, 4 was enough, 5 was nice w/ the OD, 6 is over kill
Discussion Starter · #9 ·
More gears let you keep the engine in its power band. Case closed. You guys are lazy, more the better, to a point.
However, I wonder what the torque rating is on it, or if it will live up to the legendary t-150, t-4, t-5, or ax-15 or any other crap box that Jeep has put in its vehicles.
I would love to have an extra gear in the tranny especially if it would allow me to run a lower axle ratio but still be driveable on the highway. Not all of us are able to trailer our rigs to the trail.
AARON
correct me if im wrong, but i believe daimler chrysler will also produce two other 6 speed manuals. one in the rams behind the hemi, and the other behind the new cummins 600. the tranny behind the hemi should be somewhat stout, and the one behind the cummins should be very stout (but big and heavy).
if you happen to come across a 2.7 diesel mated to a 6 speed out of an 05' liberty, let me know :flipoff2:
Rolling Mod
Tranny is out of the M series benz. Torque rating is lower than the NV3500 and fifth gear isn't as high. I wouldn't be suprised if the diff gears are changed to compensate. ie a Rubicon with 3.73 to keep freeway rpm the same. Basically the ratio's are closer together than the NV tranny.
I think they already have a 6 spd behind the cummins, dont they?
Discussion Starter · #14 ·
The trannys in the Dodge pickups aren't made by DCX, there New Venture units. NV5600 in the Cummins, I'm not sure about the Hemi, I haven't seen one with it, I wasn't even sure you could get a stick. Anybody know what it is?
The 6sp is a nice idea, but I will just NEVER understand the ,IMO, stupidity
of designing a new 4X4 transmission and making 1st gear only 4.46:1. :shaking:
Never understood that either. If you're going to give me another gear, give me either a higher OD gear or a lower first gear. I don't see a whole lot of advantage in a ~4 first gear and a .7 OD gear and an extra gear in between. Give me either a lower 1st gear or a taller OD gear and then I'll be interested.
16% lower first gear is decent, would be like switching from my 4.10's to 4.88's almost (4.76 to be exact) while crawling in first gear. I'll get one when my current tranny dies if they prove reliable. Time will tell.
1 - 20 of 21 Posts
