You can leave them out a ways and let the coils bow(This is what I did on mine) or you can grind a little of the casting in the center section to make them fit.
They're terribly crappy 60s. Unit bearing hub with a wierd, 33 spline outer. Vacuum disconnect with 2 piece, collared inner axle shaft and a 32 spline inner. There are definitely better donor 60s.
First I got it for just about nothing literally. If I have problems with the other crap it will be an excuse to get a rockstomper knucke set down the line and build my own custom 60. I actually don't mind the vacuum disco because I am going to put a spool in it and use a posi lock cable.
