1 - 11 of 11 Posts
Been throught the 63" FAQ thread, helpful but Looking for some guidance from you yota guys running em cause you know the most. Building a ex cab ranger 4.0 with a d44 up front. Got my 63's from a burban. 4 leaves+Overload. What should I remove to run em on the range. Its heavy with the 4.0 and ex cab, but I'm looking for max flex. Sometimes has my moto bike in the back but thast weighs so little I dont think it matters.
Im running the 3 leaf+overload on my runner and it stuffs nicely. Droop is something to be desired however. I left the overload there because it acts as a bumpstop.
does the front side of the overload catch rocks?
The 63 chebbys aren't really that great my buddies rear ranger spring pack flexed really well in his 85 better than chevy ones do. Even f150 rear springs I thinck are a little better. But put it together and see what you think. I wouldn't use the lift block that came with them.
I run 3 leaves plus overload because I haven't gotten around to bumpstops yet. Its a bit firmer than it should be for normal wheeling (driver, passenger, cooler, spare tire), but it works beautifully when the truck is fully loaded with gear. I think three leaves with no overload (or cut down overload) would probably be ideal, but be sure to get your bumpstops dialed.
1 - 11 of 11 Posts
