21 - 40 of 40 Posts
As 73FJ says circle the wagons! Always great to see another one coming back from the clutches of the crusher. Really dig the maverick model.
So glad you are building it with a low COG as they look comical up high!
The new shock tower position will be much stronger than the large cutout in the frame you had too.
Discussion Starter #25
Found some more shop time today. Packaging issues. Recessed the frame and mocked up tower. Full extension just barely clears. Can’t get full compression, tire hits shock. Might try a 1.5” spacer then get wheels with correct backspacing.
Discussion Starter #28
Got the pass and driver floor pans in and tookbox re-attached. Still need to patch tunnel and make the trans cover.
Discussion Starter #29
Anyone have a tubing roller in the Placerville area? I need to roll some 1/2” tubing to make some rear fender edges. Exactly like this.
Discussion Starter #30
Front shock hoops welded, I’ll make a cross bar later.
Discussion Starter #31
My uncle had a tubing roller and I got the rear fender trims bent and tacked.
Nice, I just drove my 57 for the first time today since I swapped the motor and coil over suspension. My front hoops are very similar to yours.
Discussion Starter #33
Rear ARB and gears installed. In hindsight I should have installed locker before welding on truss. Was tricky getting those little o-rings on the copper tubing.
thhhpptthh!
Kick ass. Looking good.
I kinddah wish i went this route with mine but I needed to do something other than building an offroad toy for a change.
Discussion Starter #35
Front and rear arb lockers and gears installed.
Discussion Starter #37
Changed motors again! 305 to 350 to 5.3. Anyone need a 350?
I am looking around for axles to swap under my 1961 Willys Wagon. I see you used a 14 bolt in the rear and a Dana 60 front axle. What is the front axle out of? what year?
Discussion Starter #40 (Edited)
Front 60 is out of a 78-79 Ford F-250 snow fighter package. I think I paid $900 but it was a long time ago. Got the 14 bolt from pick-n-pull. Ruffstuff has all the 14 bolt goodies including cover, guards, trusses, brake brackets and loaded calipers with parking brake provisions.
21 - 40 of 40 Posts
