Hey, first post, looking forward to becoming more active with this forum, but for now, have a question. I'm new to 4x4s, primarily have worked on classic Ford cars, but recently picked up '66 F100 4x4 with Dana 44 front, Dana 60.3 rear. My front hubs have Mile Marker lock outs and both don't function and I’m attempting to replace with new Warn units. I removed the outer lock out mechanism but now attempting to remove the inner sleeve that slides over the axle shaft and has the 6 small hex screws that hold the outer lock out assembly to the hub. For the sleeve, I’ve removed the outer wire retaining ring and inner snap ring but cannot get the sleeve to budge. I've chased the grooves with a pick where the retaining ring and snap ring reside to see if any junk is stuck in there, made a plate and used a puller, and heated up the hub with a torch until the wheel grease boiled, but nothing moves; what finally gives is the screws snap. Appears the sleeve is really rusted into the hub. What are my options here? Can I remove the spindle/knuckle and hammer the outer axle shaft out through the backside? Do I just need to destroy the inner sleeve with an air chisel or am I just entirely missing something?
Thanks!
Brent
Thanks!
Brent
