1 - 20 of 330 Posts
So I've been postponing publishing a public build thread for long enough. I'm getting to the point where getting more opinions and input on what i'm doing & where I'm headed will be incredibly valuable. So here it is.
Around november of last year I picked up a 69 f100 camper special which had no engine, a 4 speed transmission, but it stopped, steered and rolled. Then I found an engine trans combo in the form of a 429 big block and a C6. Did a rebuild, put em in. Built a cab cage. started an engine cage. now i'm in the middle of the front suspension build. That's the short of it. Pics are worth a thousand words anyway:
autofab mounts:
edit: sorry guys I moved a bunch of stuff around in my photobucket and I dont remember what pics I had up. If there's something missing that you remember seeing / still want to see, send me a message.
And then i found out that my beams weren't actually bent like I was told (that'll teach me to believe a guy about used desert parts). So I spent the past few days working on adding in some lift / ride height to the beams.
Here's how I left the truck tonight:
Frank,
The autofab motor mounts were remarkably painless to install. John (autofab guy) did a pretty good job lining up the 385 series big block to the f100 frame using existing holes. I'll take some detail pictures tomorrow.
I bought a set of heddman long tube headers, but they ended up not clearing the passenger side frame rail, so I had to do some clearance-ing with a grinder. I'm not worried about strength because I'll be adding so many tubes in that area with the engine cage build. If I was going to do it again, I would spend the $$ and get some headers that were specifically built for a big block ford in an f100 frame.
Glad to hear that you're still putting some effort into the Tank. I love that truck and I took some ideas from it when I first got the truck... we actually have some mutual friends from the poly performance/polygoats circle, so i've been able to see it in person.
Discussion Starter · #12 · (Edited)
Are you planning on using glass or lexan?
Nice fab work :)
Thank you. I guess I never did tell you guys what my plan was for the truck. For your question, I was planning on glass but lexan never even crossed my mind. I'll have to look into that.
The plan for the truck is to build a capable play truck, with no race intentions. (at least for this first iteration) This is my first full-size truck build (I did SAE baja before this) so I'm learning a ton as things go along. The front suspension, as you can probably see is to run 1 ton beams, cut for lift and plated for strength. custom radius arms on heims, coilovers. Full cage. The rear will have a 3-link with a speedway engineering full floater 9" housing which I bought trussed and tabbed for a 3 link. The tires are 35s.
Got the radius arms put together tonight. After my beam fiasco, I'm a little "gun" shy about fully welding things until it's all together. So these still have a bunch of plating and welding until they're 100% but in this state they'll be substantial enough to let me move forward with steering and shock placement. Once the front suspension geometry is completed and tacked into place, I'll weld it all up and finish the gusseting & plating.
I'm going to be moving on to doing the crossover steering next and I wanted to get some input. What do you guys think about picking up a set of pre-built or WIY swingers (giant motorsports, for example) and doing the links and mounts myself to match this application?
Also, any thoughts about the best steering box to try and get for crossover? I have a junkyard trip in my future and all I can think to look for is a box that mounts to the inside of the frame rail, extends down far enough, has a relatively flat pitman arm, and has provisions for power steering. Any input?
Discussion Starter · #17 ·
Subscribed. Good work!!
I love F-100 prerunners! Look great.
Thanks guys.
Went to the junkyard and picked up a steering box out of a 91 f250. it met all of my requirements, but we'll see how good of a choice it was.
When i was cycling my front suspension, the tires would hit part of the body mount near full bump while turning, so I ended up doing some plate work to hang the cab off the cage. As with many things... the first step to improving is admitting your weakness. I suck at sheet metal. I'm not thrilled with many of the joints of the plates to the body. I think part of it was the general fit of it, part of it may have been my lack of experience welding with thin materials, and another part is a lack of experience working with sheet and all the tricks that go along with it. I'll be re-doing many of the plate work down the road.
The reason I'm telling you guys this stuff is because I talked to a guy at work who used to do sheet metal paneling for race bikes and he mentioned that the best way to do it is to have the plate meet tangent to the tube you're working with and on the other end of the plate, round off the edge to basically "flare" the edge that meets with the body (or other sheet metal panel). This flare / rounded edge gives you a point to focus your weld (and therefore, your heat) into the now thicker plate and it should result in a cleaner weld. No more trigger welding to body panels. I'll report back on that process after I try it.
After the plate stuff was done I took my trusty plasma cutter and cut off the body mounts and a bunch of sheet metal down in the tire area. Way better. no pics of that yet, sorry.
Lastly, steering swingers are started. on with the pics.
Nice work, but what you started with looks to be a F-250. Those are definately 3/4 ton hubcaps and your later photo shows an 8 lug wheel up front.
No worries though, you can hang 1/2 running gear in that truck easily.
1 - 20 of 330 Posts
