I have a 1979 Ford RC d60 and will be ordering the avalanche double and single steer arms, with the double on the passenger side for hydro asist and the single on the drivers side.
So how long are these rod ends?
I was thinking the ES2027L and the ES2026R for the drag link.
Would these big taper, high miss alignment TRE's perform well for the tierod also?
Are they long? Are there shorter ones that would be better?
Any sugestions on my pitman arm? Its going on a Jeep cherokee XJ, I think Im currently using the ES375L & R 3/4-16 rod ends..I was thinking of drilling it out then use a tapered insert either weld in or not.
I DID A SEARCH.
And this is what I found
Thanks..
STEERING PARTS:
$7/ea 2x P/N:14026805 (left hand) left hand jam nuts 7/8-18 Chevy dealer
$7/ea 2x P/N: 14026806 (right hand) right hand jam nuts 7/8-18 Chevy dealer
$?? 1.5inX 250 DOM Tubing for inserts (9ft)
$50 1.25 x .219 DOM tubing material for taping (9 ft)
$50 P/N 2595A424 7/8-18 right hand TAP McMaster-Carr (http://www.mcmaster.com)
$108 P/N 2595A999 7/8-18 left hand TAP (Special order) McMaster-Carr (http://www.mcmaster.com)
7/8-18 TRE's:
ES437L- (0.594/0.703) has a stud length of 0.0.872. it is bent. 3.95" long.
ES454L- (0.612/0.703) stud length 0.728 straight - 4.0" long
ES380 L & R - (0.612/0.703) stud length 0.728. straight - 5.56" long.
ES113 L & R - (.760) big taper $50
ES2234R $23.99 driver side tie rod 7/8"-18
Application: 85 Blazer
ES2233L $25.99 pass side tie rod 7/8"-18 WITH HOLE FOR DRAG LINK, for T-geometry steering.
ES2027L $18.99 high misalignment drag link end Passenger side 7/8"-18 threads, BIG taper
Application: ??
ES2026R $20.99 high misalignment drag link Pitman arm side end Are 7/8"-18 threads, BIG taper
Application: ??
ES2011R & L
ES2010R & L $40 each 7/8-18 right and left hand thread TRE
I DID A SEARCH.
Thanks..
STEERING PARTS:
7/8-18 TRE's:
Application: ??
Application: ??
ES2011R & L
