I have a TH700R4 in my Explorer (AA kit) with aprox. 25K on it. Until recently it worked perfect. In the past few days it has started to slip on the 2-3 up shift and will not hold overdrive if under any load. Fluid is full and clean.
Some things you should know about the tranny. The TV has always been a little tight (had to back off throttle to get it to drop into OD) and the lockup on the torque converter has been hit and miss (it worked fine on flat land but not so well if pulling a grade).
Any thoughts as to why all of a sudden it started acting up?
