The 3.2 has the GM 60* pattern. I'm running a 700R4 behind mine from a '86-87 2.8L S-10.
Bolts up pretty nicely
The 3.2 has the GM 60* pattern. I'm running a 700R4 behind mine from a '86-87 2.8L S-10.Does the Isuzu 3.2 and GM engines used in the Isuzu's share the same bolt pattern? Just curiuos if a 700R4 would bolt behind a 3.2?
how do you like it?Andre75 said:The 3.2 has the GM 60* pattern. I'm running a 700R4 behind mine from a '86-87 2.8L S-10.
I like it a lothow do you like it?
Try looking into using a Scout driveshaft. They are about a 1" or 1.5" diameter shaft.Andre75 said:I'm running a shortened stock front driveshaft, so I could probably go with a smaller diameter and be OK.
Stock starter. I left the flex plate in place, and spaced back the torque converter.what did you do for a starter?
Here is the stock trannyGot any pics of the bellhousing differences between the two trannys?
