1 - 4 of 4 Posts
Ran across a truck today and wanted to know more about it. Been searching for awhile and haven't come up with any good info. Here is what I have by looking at the truck:
-Its an International :D
-It is registered as a 72 1 Ton
-Unknown dually rear with drop-out third
-V8 gas engine
-closed knuckle Dana 70 front
-looked to be a divorced NP205 t-case
Here are the questions I have:
What engine would that be?
What tranny?
What kind of rear axle is that and what are the specs?
Specs on the front 70?
Gear ratio?
Thanks guys,
Dave
IH/Rover Moderator
What engine would that be? 345 or a 392
What tranny? stick 4 or 5 speed or auto?
What kind of rear axle is that and what are the specs? IH corp axle
Specs on the front 70? like what? it's a drum brake 70
Gear ratio? open the glove box and pop the two clips there should be a build sheet taped to the back of the box
I am an IH moron. I really know nothing about these things. I REALLY liked this truck though so I wanted to know more about it.
-Are there any visual things that I could look for to tell me whether it was a 345 or a 392?
-The tranny was a manual, and I didn't even think to jump in to shift the gears to see how many speeds, I just kinda assumed it was a 4 speed. I'll try to go do that soon.
-IH corp axle huh? That is a cool lookin axle! What sixe ring gear we talking? Spline count? Shaft diameter?
-On the 70 I was really wondering if it uses those tracta joint dealies, and of course the axle ratio, but I will try to go and fiddle with the glove box to figure that out :D
Thanks for the reply!
Dave
The little boss on the engine that says what the CID is would tell you.
http://www.binderbulletin.org/faq for a picture of the spot, just under the right head, on the side, just above/behind the fuel pump.
1.5" shafts, 11" ring gear.
4.30 was the tallest ratio available, this truck may likely have 4.88 (the next step)
1 - 4 of 4 Posts
