Blue and white,
Engine:
460 with under 500 miles
Edelbrock Carb model 1411
Edelbrock Performer intake
Heads are ported w/ new valves and guide plates
Crane roller rockers
Comp hardened push rods
Comp timing chain and gears
Comp cam-Intake 218 degrees and exhaust 226 degrees
Holley fuel pump
Hooker Headers with frame mounts
Glasspacks
Morriso deep oil pan
New motor mounts
Forged Pistons (.030)
Rods and Crank
MSD ignition
Also have a 460 block that can be added to the deal and save you some hassle of finding one.
Tranny:
C6, rebuilt with under 500 miles,
High torque convertor
High torque clutch packs, etc. and
Tranny cooler.
Riding on:
D44 front/Discs
D60 rear/drums
BFG 33" AT's in all four corners-Under 500 miles
Divorced NP205
New brakes and lines
New U-joints in the trans to t-case shaft and front drive shaft
Interior is in great shape except for carpet. The exterior has rust around the rear D-side wheel well and a dent on the front D-side fender.
The block is cracked and may need to have crank replaced and a rod.
Have over $10,000 into the truck and NO time to finish it at this point. Willing to part ways for $5,000.
Posting this up for a Buddy. His name is Cody and you can reach him at (619) 252-0408. No pics at this time but it's being worked on.
Engine:
Holley fuel pump
Glasspacks
New motor mounts
Rods and Crank
MSD ignition
Tranny:
Tranny cooler.
Riding on:
D44 front/Discs
D60 rear/drums
Divorced NP205
