Ok so I am starting to tear down the d44 to gut it and then cut the long side. I take off the automatic hub cover and take off the spring clip on the axle shaft. Next the axle shaft washer (inside splines fit over the shaft) and the damned thing wont come off. So I think ok a little pressure and it will break free. No go. I spray enough PB blast to kill a man and still nothing. I try to blue torch it on the washer to have it expand then big ass flathead behind it and still nothing. WTF?? There is nothing in the way of it sliding off the axle shaft spines. There cannot be a way for a thin washer to be so rusted on to the shaft that it wont come off is there??? I was so pissed I sprayed even more PB blast on it and put the freakin cover back on to let it sit.
Anyone else have this kind of problem with an automatic locking hub set up?
