1 - 3 of 3 Posts
Although its not unibody I have a question that hopefully someone here can help me answer. I have a 4" BDS Spring lift and just recently moved my shackles on front of vehicle to rear. I positioned my shackle mounts in frame with. 125" dom and new urethane bushings all the way around. Built fixed mounts for front out of 3/8 plate. Everything is great except the axle tracks left and right badly. My best guess is I need a track bar (doesnt have one). Prior to this reversal I had wornd out bushings and lighter mounts
and shackles. Why do I now have this problem. Thanks for input
Discussion Starter #3
Caster is 5° to front pinion angle is 10°. I built my fixed mounts to maintain same angles I had before. I forgot to point out I extended my axle forward 5" during this process. My main issue is the amount of travel the axle has from left to right when wheel is turned from a dead stop
1 - 3 of 3 Posts
