well.... i picked up a 79 bronc that i want to build, i have a 96 f-350 that has a salvage title...= not worth much to resale...soooo i want to swap in the f-350 axles to the 79.... i know at least 1 guy on here has 1 ton under a bronco....but he used leafs up front...i'm wanting to build a new radius arm that instead of using c-bushings......bolts to the leaf spring mounts on the axle......i was just wondering if anyone had done something similiar and if they had pics....i have an idea of the design...but always open to suggestions..... the other question is...the 10 1/4 has ABS....i don't think it will have any negative affect...but i don't know everything.... heard of swapping in 2wd F-350 master cyllinder for the brakes....is this the easiest way??
Thanks
Thanks
