2000 Jeep Wrangler Sahara
best to reach me via email [email protected]
Pictures with 37" Tires after I built her up and recently with 35" Tires.
Owned since 2004 and really built her up about 10 years ago, but with work and kids, I just don't get to use her. She's a good rig, just needs some finishing touches and a little TLC to make her great.
- Engine
- Stock 4.0L I6
- ~95,000 miles
- Runs great
- Need radiator
- Wheels and Tires
- Black Steel Wheels
- 35x12.50xR15 Toyo Open Country Tires on black steel wheels, good condition, one isn't currently holding air.
- Transmission
- Stock Manual NV3550
- The Novak Guide to the Jeep NVG 3550 Transmission
- Replaced under warranty around 60,000 or 70,000 (bad synchros?)
- Jeep dealer said it was cheaper for them to replace under warranty than fix
- Transfer Case
- Updgraded from 2005 Automatic Rubicon
- NVG241OR Rock Trac
- The Novak Guide to the New Process / NVG 241OR RockTrac Transfer Case
- Heavy Duty with 4:1 low range
- Front Driveshaft
- Stock
- Rear Driveshaft
- Upgraded – Tom Woods Driveshafts
- Custom Drive Shaft Shop | Tom Wood's Custom Drive Shafts
- 1310 Universal Joints
- Front Axle
- Stock Dana 30
- Lockrite Locker
- Lock Right Locker - PowerTrax
- Has wheel adapters to convert from stock 5x4.5 bolt pattern to 5x5.5 bolt pattern to match rear
- Should have some spare axle shafts
- Full width truss for added strength
- 4.56 gearing installed by 4 Wheel Parts store in Tempe, AZ
- Currie HD Steering Upgrade
- http://www.currieenterprises.com/CE-9701
- Rear Axle
- Ford 9-inch from 1977 Bronco
- 31-spline, old style big bearing
- Wilwood Disk Brakes
- Two 3rd members
- 4.56 gears and Detroit locker from Currie
- 3.73 gear and limited slip (came with axle)
- Upgraded Currie axle shafts
- 1 set of stock spare axle shafts
- Front Suspension
- 4” lift coils
- Custom Long-arm 3-link suspension with trac bar
- I would lengthen the upper link by 1” and move the trac bar frame mount forward about 3-inches. This will allow you to dial in the front suspension better. Right now, the upper link mount on the axle will hit the trac bar mount of adjusted correctly.
- Frame and axle brackets by Ballistic Fabrication
- High quality parts for fabricators and off-road enthusiasts
- Bilstein 5100 shocks
- BILSTEIN Corporate - BILSTEIN
- I would add limit straps so the shocks are not limiting factor
- Rear Suspension
- 4” Lift Coils
- Custom Long-Arm triangulated 4-link
- No track bar
- Custom “Frenched” shock mounts allow for longer shocks and keep them out of wheel travel
- Other
- 1” Body Lift
- Oil Pan Skid Plate by Nth Degree Mobility
- Custom rocker guards by Hunter Offroad, Tempe, AZ
- Aftermarket rear bumper with 2” receiver
- Stock hard top
- Full soft top (no frame, sits on roll bar)
- Bestop Halftop
- https://www.bestop.com/jeep/2000/wrangler/half-top/
- Both soft tops have some damage from mice/squirrels.
- Full cage with seats tied into cage, Stock cage from B-pillar back, added Cage from A-pillar to B-pillar
- 5-point harnesses
- Warn 9.5ti Thermometric Winch, Milemarker E8000 winch, both need work but worked well before.
- Air conditioning
- Raised Hood and front fenders, “high line”
- Fits 37” Tires
