no it doesn'tdoesnt the speedo read off the tail cone of the t-case?
thats only on older trucks, 91' and older IIRC.XJ_ranger said:doesnt the speedo read off the tail cone of the t-case?
what is the problem with swaping the axle?
94 Bronc, ZF tranny was 8.8 now 10.25 speedo works fine, comp works fine. ALL wiring for tranny removed up to main harnesstsmall07 said:well i am planning on switching to an older zf tranny, but i don't know if that has the speed sensor in it or if it was in the t case. even if it is in the tranny, how can i hook it to my truck? i can't imagine that the conections are the same or that the computer would support it.
64mm (2.5"+-) SHORTER than the E40D. I used my same 1356 as Ford did in the F250/350. I took the E40d tranny crossmember and fabbed a bracket w/ 3 gussets that also raised the back of the Tcase about an inch. Shortend front, leghtened rear DS. Waalaatsmall07 said:nice
did you have any issues with the length of the zf? i hear that its 2" longer
and what t case did you use?
Tcase yes,tsmall07 said:i have the mazda 5 speed and i don't know what t case....if someone knows if i can used my same tcase let me know, or if i'll be able to use the same drive shafts?
