1 - 15 of 15 Posts
more specifically what front axle with a 15x10 wheel with a 4.5 inch backspacing fit and clear the brakes? after searching ive vaguely found that they will fit on a chevy 60f? im still unclear about this
i can only assume that these wheels will fit something?
I have 15" wheels on a ford D60 with 4" of BS. I had to grind the crap out of the brake caliper.
Pyagid said:
I would guess they will will also fit the Jeep D44 Front. (8 lug version) I assume on a D44 the calipers are smaller than a d60
The calipers on an eight lug D44 are smaller than a D60, but the rotor has a larger diameter than the six lug D44, putting the caliper closer to the rim part of the wheel. Plan on grinding on an eight lug 44 also with 4.5" of backspacing.
Fistful of Boomstick
actualy with that much backspacing you will probly be running "reverse center" rims and these will cause problems other than just the caliper grinding if it come time to bead lock them
Is there a specific reason you want that much backspacing??
might be able to find a simple solution for you :D
need about 3 1/2" backspacing to fit 15's on a Ford Dana 60 and some griding on the dual piston calipers too.
Discussion Starter · #13 · (Edited)
i was wondering because the rims came with the tires i bought, i guess now i will be ditching them,
it just seems odd to me that they would make a rim that doesnt fit anything
who sells some cheep steel wheels with 3.5 inch backspacing?
search and ye shal find :flipoff2: click here
1 - 15 of 15 Posts
