1 - 17 of 17 Posts
'81 cj 7 100" wb
spring over with wrangler springs
5.3 from an '04 avalanche with 30k miles
atlas 4.3 passenger drop with 32 spline outputs
th350
flat skid plate
dana 44 front with 4.88 gears, a detroit and tri county gear high steer
rear 35 spline dana 60 4.88 gears full spool
37x13.5x15 procomp xterrains on 32 bolt beadlocks
roll cage only used once.
body is a little rough.
$6000 obo
pics:
http://s725.photobucket.com/albums/ww260/juicywhip13/
Discussion Starter · #14 ·
From what I was told, the cj frame should bolt up to the yj tub. I was planning on cutting off the stock mounts and moving them up. I can throw in the tub for $200. The jeep has zero issues. Everything works great. The tires have about a .5 inch of tread left. They have never been driven on the street, just three seasons in the rocks.
Regarding the frame, my understanding is the the cj has some weak spots or is much weaker than the yj frame, so I know that some people weld extra plate, etc. to it
is the axle in front high pinion?
the yj tub have dents or any body problems?
Discussion Starter · #16 ·
The frame is stock, but I have never had any issues with it. I could get a yj frame too, but at that point its really just starting over. The front axle is low pinion and the yj tub is the blue one pictured on my photobucket. It is basically in good shape except is has a large dent in the driverside firewall. It looks like it will be pretty easy to straighten out. It isn't a show tub, but shoud work great for a rock jeep.
1 - 17 of 17 Posts
