21 - 40 of 250 Posts
I wasn't saying he hadn't used appropriate means to get his tires/wheels.
I just know that I have "acquired" enough random stuff in my 4 years of service to know that these things happen.
Discussion Starter #23
question: should i weld something in between the 2 sides of the shackles? if so i was thinking some thick tube through those holes.
also, im most likely going with the 3 link kit from ruff stuff. the only thing im worried about is heims on the frame end of the lowers. should i replace those for solid bushings. or just go ahead with the heims? keep in mind its going to be streetable...
thanks
-Shomsky
You are planning on replacing the rear crossmember right?
While your doing that I would move the hanger forward. Its not going to settle as much as you think it will.
Discussion Starter #26 (Edited)
yes crossmember is getting replaced with hitch tube thing between the ends of the frame.
as for the shackle angle. it will probably be easier for me to cut a section of the frame out and sleeve it or something.
im thinking the shackle should be hanging straight down before there is any weight on it?
edit: if i make the shackle angle slightly less than 90* (swinging more to the back end) at full droop, and being forced down slightly to compensate for the axle/tire weight. i should be good right?
That should be good, shackle should be perpendicular to ground with no weight on it.
I'm definitely going to do that. I was just wondering if it matters if I have anything welded between the two pieces of shackle.
oh my bad miss read your question i guess:shaking::homer:
Discussion Starter #35
I'm about to drop a grand on a front Dana 60 this weekend. I've searched high and low for cheaper 60s and can't find anything. Is there anyone remotely close to me with a cheaper 60? Or some kind of cheaper/just as strong option that I'm not thinking of? Thanks -Shomsky
Discussion Starter #40
Got a Chevy Dana 60 from an 87 V30. A lot of rust and corrosion inside the passenger hub. It was a real pain in the ass pulling the hub off the pass side. But got everything apart now and working on cleanup/paint.
Pics:
Maybe some of you can help me with options:
-35 spline outers with a 35 spline flange kit. but with that comes:
-an expensive selectable locker...
-wont be able to run an inexpensive square front driveshaft...
-just run the stock front 30 spline and selectable hubs, with a lunchbox.
Is there a 35 spline flange kit using the stock selectable hubs?
