here are the specs:
stock 360
stock trans and t case
high pinion 60 front
14 bolt rear
39.5x15x16.5 tsl
h1 beadlocks
body is removed from frame. I am blasting the frame and por15 the frame and underside of body.
ordering spring perches for the 60 and 14 bolt
high steer arms for the 60
blah blah blah
Now i want to spring over with little lift. What springs did you use? what could i pull from a junk yard that anyone has had luck with? This is going to be a very low budget build......:flipoff2:
stock 360
14 bolt rear
39.5x15x16.5 tsl
h1 beadlocks
blah blah blah
