1 - 6 of 6 Posts
Unfortunatly, I don't own a TIG.....yet, but here is a project I am working on called 10slow. I needed to install an interior rollbar, but the floor was soo rusted, there was nothing to bolt or weld it to. So, I cut out the floor, re-supported the mounting areas with steel, then replaced the floor with aluminum. Next I will build the cage, and then try to mount some lighter weight seats.
Oh, I am also dropping 60lbs from the weight of the vehicle. All together I have cut out about 300lbs of crap.
I welded on new steel plate where the old mounts were. Thee original ones were complety rusted out.
1 - 6 of 6 Posts
