1 - 6 of 6 Posts
Anybody know where I can find wiring schematics? I swapped Np833 inplace of th350 and everything is swapped but am having wiring probs. Got rid of donor truck so I cant refer back :shaking: Thanks in advance:D
Hmmm.... what problems?
I did an auto to std swap on my '84. Only wiring changes were things I unplugged. The only thing that doesn't work is the backup lights. (Actually, it still does if I swing the column shifter to right spot.:laughing: )
chris walker said:
isn't that a weak trans why didn't you go sm465 then no wiring problems because no wires
The wiring wouldn't be any different for either std. trans.
He probably chose it because it has OD. I think A833 is the Chrysler name for it. RPO code MY6 for GM. Or NP440 as per New Process.
I used the A833 because I had it. I am still locating parts for a NV4500 swap. Troubles coming from swapping manual 84 column into 81 2wd cab. I get power but no crank, probably clutch safety switch(?) I also have probs w/power stick my 81 has it all in dash/floor but 84 has on column. I know its all BS stuff but this is a DD/shop truck so these are necessary items. thanks for help.
1 - 6 of 6 Posts
