1 - 4 of 4 Posts
we have an 85 grand wagoneer, with a cracked 229 transfer case. also have a 79ish wagoneer, but not sure what transfer case is in it. will the two interchange? didn't know what the options were in the wagoneers, i'm trying to help out a friend who has cancer. just need to get it where he can drive it again. started out needing a starter and then found the cracks in the case.
Well there is a big difference between 1979 and 1980 when it comes to jeep fullsize transfer cases. In the late 70's jeep ran th400 transmissions mostly behind the Borg Warner Quadra-Trac. That transfercase won't work for a number of reasons (spline count, offset rear), but the main reason was the front driveshaft is on the passenger side. If the wagon is actually a 1980 then chances are it is a np208 with a torqueflite and that should have the same bolt pattern and spline count as your np229 and most importantly it has the driverside front driveshaft
was finally able to go and look at the other one, its an 82 and it has a 219 transfer case in it. is one or the other better? should i swap or just try to find another 229? thanks.
The bolt pattern and spline count should be fine; however, the np219 was a full time 4wd transfer case. Your shift pattern from top to bottom would be (4 positions) 4l-n-4h- and "lock". The 4wd lock position is for use when the vehicle is immobile due to excessive wheel spin.
1 - 4 of 4 Posts
