1 - 9 of 9 Posts
hmm not sure heres what im lookin at, Ive got a SWB 86 Montero, i can use front lift shackles from an old toyota to give me a 2 inch lift on the rear because it uses the identical ones that toyos do on the front. So im not sure what an Offset shackle is can u explain?
This is what i used before to lift my other montero.
get a 3/8 steel bar and drill a hole in each end. if you need to offset, cut a short piece and weld it to one end so it is thicker before you drill the hole. If you don't have access to the equipment, I can make a pair for $25+shipping or you can pick up in the bay area. Not sure where you are though.
1 - 9 of 9 Posts
