1 - 9 of 9 Posts
I am selling Rubizuk. It is a 1987 Samurai that has a 1.6L sidekick 16 valve engine, with an 4 speed auto trans, toyota axles with electric lockers & 510 gears, 6.4 transfer case with twin sticks. The body has been stretched 23" and now has a 103" wheel base with 37" tires on bead locks.
The engine, transmission and drive train are in excellant condition, the body does show wear and tear from several years of use. all of the body damages are all minor.
It also has a cab roll cage, Warn PowerPlant winch, custom steering, two top's.
I am asking $8,000.00 and I am located in S. Calif.
Larry 951-609-4455
Is that a steering rack? How does it work?
Discussion Starter #8
Pass ca smog?
Drives on the road ?
Any problems?
I just rebuilt the front axle, bearing, seals, spindles. The trans has about 500 miles on a rebuild, engine has about 2,000 miles.
I have driven up to Big Bear (our local mounts) from where i live. about 80 miles each way. It is not a great hwy vehicle, but at 55 mph it will get you there. The vehicle will go faster, but with 37" tires, i don't trust going any faster.
Petro works got it to pass smog the last time. I don't see why it would not pass this time.
1 - 9 of 9 Posts
