Hello all! Recently got an 88 samurai and its pretty fun, however more power is desired. Instead of doing the "usual" 16v or diesel swap, i decided to go with a nissan KA24DE engine from a 240sx. Going to be a lot of work, but I think I can get it done.
This was the samurai before I removed the stock 1.3L
This is the KA I picked up
This is the trans
And here is possibly the worlds smallest driveshaft
The trans is actually an early 80s nissan pickup truck trans, but it has the same bolt pattern on the bellhousing for the newer KA24DE, so it should bolt right up. it is considerably shorter tha nthe 240sx trans, but is still about 5-6 inches longer than the samurai trans. Hence the tiny driveshaft. But, that will probably have to be lengthened anyways. Might have to make my own or find a CV joint to lengthen the driveshaft just right.
In order to mate the nissan driveshaft flange to the tcase input flange, I had a buddy machine out the counterbore in the tcase flange to accept the nissan flange, and match drill the bolt holes. I should be picking that up later today.
Once I get the engine and transmission in the samurai, and I know it will fit up, I will be going through the stock wiring harness and removing anything having to do with the old engine/carb/ECU to clean it up and simplify the wiring some.
Will try to post new pictures and info as I go, but I am also in the middle of rebuilding my enclosed trailer, and that takes precedence so I can get it done and out of the middle of my driveway!
Stay tuned!
This is the trans
Stay tuned!
