1 - 3 of 3 Posts
New here, I'm probably gonna get flamed like crazy for this but whatever...i don't feel like filtering through a million posts to get an answer or help.
I have an 89 pickup with a 22r that isn't getting spark. So far I've replaced the ignition switch, coil, pickup coil, ignitor and checked all my grounds and fuses with no luck... the truck still has no spark. I have power going to the coil, but the plug that goes from the ignitor to the pickup coil in the dizzy has no power at all at either wire (they are a red and a white wire I believe)
Any help? What am I missing? Could the distributor be bad or is there a resistor or something somewhere I'm not checking??
Make sure your air inlet plumbing is hooked up, the ECU is looking for that signal before it will send the signal to provide a spark from the coil.
Discussion Starter #3
Air inlet plumbing? It's just an air filter sitting on top of a weber carb, as far as I know the 22r doesn't have an ecu.
1 - 3 of 3 Posts
