1 - 7 of 7 Posts
I have a 89 1 ton 4x4 chev that I use for towing my fj40. I've been having trouble with the engine.I has no wear near the power it had in the past and it has a terrible miss. When I step on the go pedal it falls on its face like a bad accelerator pump on a carb. This a 454 tbi. I scanned it (snap on scanner) I came up with a code 44 sustained lean condition. It does feel like its not getting enough fuel.
Replaced the egr because I heard they were very troublsome. Didnt help at all.
Any suggestions?
Thanx in advance
Shaun
Try the throttle position sensor.When they go bad they will act like a bad accelerator pump.
Check your fuel pressure also. A clogged filter or bad pump could cause those symptons. I think it needs to be close to 13PSI
Originally posted by Norm:
<STRONG>Check your fuel pressure also. A clogged filter or bad pump could cause those symptons. I think it needs to be close to 13PSI</STRONG>
I would bet a large some of money that the fuel filter is plugged solid. Its amazing how little fuel they will run on.
Does the service engine soon light come on and then go back off while driving? GEt new O2 sensor first
I replaced the o2 with no luck. I want to check the fuel pressure but I dont see a fitting to put a guage on. Are they hidden somewhere or do I have to connect it in line somehow?
Thank you guys,
Shaun
1 - 7 of 7 Posts
