Here is my 1uz swap into my 4runner.
Frist,My turbo diesel build http://www.pirate4x4.com/forum/toyota-truck-4runner/847890-mercrunner-build-up.html So you know where I am starting from.
I realized after being told by a few people that my 4runner with 1tons and 42's was going to be lacking power, well they were right.
I ripped out the old diesel and got to work on the new setup.
Specs:
93 sc400 1uz without traction control
2000 Tacoma R150f
Southbend 3SGTE stage 2 OFE clutch
1uzswapkit.com adapter for R154
Modified 3vz flywheel from 1uzfeswapkit.com
TG R150f gear t-case adapter
Stock duals with 23 spline stuff and longfield output
Remove the FJ60 steering box and replace with a IFS box
Long Range Off Road 2lt aluminum radiator
and the rest is the same
Engine is in, runs, ecu in the glove box, and mostly put back together.
I'll give more details later.
Specs:
2000 Tacoma R150f
