1 - 7 of 7 Posts
Is there anyway to install the tapered bearing on the 9" axle shafts without using a press? Also what's the easiest way to remove them? My local shop charges like 30-40 bucks each to install and remove with a press, thanks, Judd :confused:
Judd said:
Is there anyway to install the tapered bearing on the 9" axle shafts without using a press?:confused:
Yep, BFH and a piece of pipe longer than the shaft. Make sure you set the shaft flange on something besides the studs. BFH and a chisel will get the old bearing off. It does work.
Press would be much better.:D
I've taken them off by drill a hole is the sleeve then into the race with a good bit. Once the hole is in the sleeve and race hit with good sharp chisle usually breaks first try. Then put axle in freezer for awhile heat bearing and sleeve in oven drop heated bearing over frozen axle
does that work very well? Or is it just a big pita? what about grease?
1 - 7 of 7 Posts
