1 - 14 of 14 Posts
Factory case? I would think the case should have broke and spit the pinion support out, before the caps
What's the story behind the carnage?.....tire size, motor, situation, terrain, etc.?
Apparently its quite common with the ford gray iron cases. I did the same thing to one a couple of years ago before upgrading to the Nodular race case from Currie.
I broke many main caps as well. they seem weak in stock form when abused alot. a nodular case will solve that problem.
I broke 4 sets in 2 years, it was always the caps, with a 351,435, 203/205 5.13's and 38"s
Wow... all looking around on the net I have never seen that before. I have a True Hi9, I hope it doesnt do that. 35 spline and ARB would be shot Im sure.
i did the same thing on my old tj ,1978 ford 9" rear 4.10 gears / arb / 37" mtr's / auto / 4.0L bored and stroked to 4.6L. gave it hell climbing the double whammy in moab ( made it too !!), drove up the trail 100 yards climbed small ledge and pow!!! both caps broke:mad3:
I'd guess mine would have ended up the same way if I hadn't stopped right away.
In a '91 Bronco, tired 302, Mazda 5-speed, 3.50 gears, 35's. Moving snow.
no probs so far on mine and it's still the stock case. has a full spool, 4.88s, 4.3 in a 5200# rig, 37s.......
I beat the living hell out of it 2 weeks ago at the Superlift park and it held up great. the yukons up front did a great as well. too bad I grenaded a hub :grinpimp:
hope ya get it fixed and back on the trail soon
I did have one issue with mine though. I had a mini-spool in it for a while and I was hopping it pretty hard. I heard a loud bang and it felt like it came from the rear. I thought I trashed a pinion gear. it ended up being the pin for the mini was split into 3 pieces. everything else held up.
tweaked a stock shaft as well
i broke mine the same way, except mine was because i broke a shaft. the splines exlpoded, and from there on out.... :nuke:
i did mine with a 6 Cylinder. :flipoff2:
mine was a 31 spline factory case. now i have a Strange nod. 3rd member and 35 splines... no problems now... (ive got 39.5s on it now... i had 37s on it then...)
1 - 14 of 14 Posts
