1 - 2 of 2 Posts
I just rebuilt the third member and I am ready to put the 9" back together.
After installing the 3rd...do I need to grease the shafts or anything before installing them back into the axle housing?? Should I put the gear fluid in before or can I add it after the axle is all buttened up??
What kind of shaft seals do you have?
Is the seal on the shaft or in the housing?
I put some gear oil on the carrier and pinion bearing before assembly. The shafts I put some gear oil on them if they are the kind that have the oil seal on the shaft.
Slap it together then add gear oil until full.
1 - 2 of 2 Posts
