1 - 5 of 5 Posts
The engine block on the passenger side just below and to the rear of the turbo has a additional transmission oil cooler with the engine water
running through it .....has ruptured and NO more new parts are avail. from dealers.
What aftermarket "bolt in" coolers are avail or where can I get the OEM/NOS
cooler?
Note: This is NOT the up front external oil cooler by the radiator.
[email protected]
thanks
denny
go here, http://www.dieseltruckresource.com/dev/index.php
i dunno if ther eis a direct replacement or not. i would by pass the engine mount one anyways because the hot coolant will make the trany fluid temp rise and vice versa.
go with a flex a lite under teh bed style cooler with a fan on it. thats my next plan.
jiMMy
now that I think about it I have a core 3.9 at work that I could swap the used oil cooler from and put on your bad cooler?
I could even have the used one tested if you want?
PM if your interested if not no wory call cummins Im sure its still available
1 - 5 of 5 Posts
