1 - 6 of 6 Posts
I am converting a 90 4-Runner that was 4x4 with 3.0 to a Chevy 350 with a 700 R4 and in the process it will be swapped over to a sas and a custom front straight axle, it will be a 2wd once completed and will sit up as this will be a pre-runner style street legal truck. My question is this, how can I adapt my speed cable to the 700R4 as I will not have a transfer case? Any help would be very nice. You die hard crawlers don't beat me up to bad as I have went through many 4x4s and that is not what I want or need in this one. Again, thanks for any help. I am also going to run the waggy stock springs and need to know can I mount the hangers in the factory Toyota mid 80's loaction on the front spring mounts and rear shackle mounts or do they need to be re-loacted because of the lenght of the springs?
Dude, this is the Pirate4x4 Bulletin Board. Notice 4x4? Not the Pirate It Looks Like a 4x4 But Its Not Bulletin Board. I think that you should keep it a 4x4, there is no reason to go SAS and not use the front axle.
1 - 6 of 6 Posts
