4 cylinder manual trans Monteros have the shifter for the trans built into the t-case. Not sure on a '91.
The drive is on the opposite side vs the Montero t-case, a 231 swap might be better with an automatic. the drive is on the correct side that way, and the shifter is easier to adapt rather than flipping the Dana 300.
Not sure of the spline count on the late V6 Montero. 23 is the common jeep spline count. the older 4 cylinder sticks had a smaller 24 spline.
The Montero 4 speed OD auto is basically the same as the jeep XJ AW-4, IIRC. Might be able to swap the output and extension housing to jeep parts if they are different.
